.Net6 Flex Grid Scrolling on Selection with CellRange SelectionMode
Posted by: frugamas on 20 May 2022, 6:28 pm EST
    Posted 20 May 2022, 6:28 pm EST
    I’m working with .Net6 Version of the FlexGrid, v6.0.20221.209.
    I’m trying to use the CellRange selection mode and I’m getting some un-wanted behavior. The behavior can be reproduced in the Selection Modes page in the FlexGridExplorer sample.
    To reproduce:
    • Click and select the first cell.
    • Scroll to the bottom of the table with the scrollbar.
    • Click on the cell for the Address column on the last row.
    • Unwanted behavior. The grid scrolls back to the top of grid.
    Is there a way to override the behavior, so that the grid does not scroll to the top?
    Felix
  • Posted 23 May 2022, 5:22 am EST - Updated 4 October 2022, 8:27 am EST
    We are unable to replicate this behavior at our end i.e., grid doesn’t scrolls to top while selecting last cell of Address column which is correct behavior.
    Please refer the attached Gif for the same:
    Could you please provide a small stripped sample replicating this behavior. So, that we can assist you accordingly.
    Nitin
  • Posted 23 May 2022, 9:30 am EST - Updated 4 October 2022, 8:27 am EST
    Sorry Nitin, I left a crucial part in the description of the issue and steps.
    I’m trying to select continuous cell.
    To reproduce:
    • Shift+Click on the cell for the Address column on the last row.
    Felix
  • Posted 24 May 2022, 3:32 am EST
    Hi Felix,
    Thanks for the detailed steps.
    We have reproduced this behavior at our end. This seems like a bug. So, that we have escalated it to the development team. We will get back to you once we have any update from them[Internal Tracking Id - C1XAML-29498]
    As a workaround, you can handle PreviewMouseDown event as:(see code snippet)
           private void Grid_PreviewMouseDown(object sender, MouseButtonEventArgs e)
                if(Keyboard.Modifiers == ModifierKeys.Shift)
                    if (grid.SelectionMode == GridSelectionMode.CellRange)
                        var ht = grid.HitTest(e);
                        if(ht!=null)
                            if(ht.CellType == GridCellType.Cell)
                                if (grid.CursorRange != null)
                                    var r1 = grid.CursorRange.Row;
                                    var c1 = grid.CursorRange.Column;
                                    var r2 = ht.CellRange.Row;
                                    var c2 = ht.CellRange.Column;
                                    var row1 = r1;
                                    var row2 = r2;
                                    var col1 = c1;
                                    var col2 = c2;
                                    if(r1>r2)
                                        row1 = r2;
                                        row2 = r1;
                                    if (c1 > c2)
                                        col1 = c2;
                                        col2 = c1;
                                    grid.Selection = new GridCellRange(row1,col1,row2, col2);
                        e.Handled = true;
    Please refer the attached sample for the same: FlexgridContinuousSelection.zip
    Nitin.
  • Posted 24 May 2022, 4:49 pm EST
    Thanks Nitin.
  • Posted 4 August 2022, 11:08 am EST
    We are happy to inform you that, this issue is fixed in 2022v2 release.
    Please download the latest ComponentOne Control Panel from https://www.grapecity.com/componentone/download and install the latest 2022v2 build.
    Nitin.
