Numeric Formatting with non-period Decimal Point separator
Posted by: msloan on 28 October 2020, 7:56 am EST
    Posted 28 October 2020, 7:56 am EST
    I am finding the floating point numbers formatted with N or F into string are appearing with PERIOD decimal points even though the system’s decimal point separator is set to a COMMA. I have found this the case with Text Boxes and the Data Grid. What am I missing?
    Mark Sloan
  • Posted 29 October 2020, 3:41 am EST
    Hi Mark,
    This behavior is by design in WPF as Binding doesn’t respect the CurrentCulture by default i.e it uses the neutral culture settings. Therefore, In order to make it use the current culture we have to set the Binding’s ConverterCulture property as follows:
    <c1:DataGridNumericColumn Binding="{Binding Sale, ConverterCulture={x:Static glob:CultureInfo.CurrentCulture}}" Format="F" Header="Sale"></c1:DataGridNumericColumn>
    Just in case needed you can also create a CustomBinding class so that you don’t have to set ConverterCulture everywhere as follows:
    // C#
    public class CustomBinding : Binding
          public CustomBinding(string path) : base(path)
               ConverterCulture = CultureInfo.CurrentCulture;
    // XAML
     <TextBox x:Name="txt" Margin="5" Width="100" Text="{local:CustomBinding Value}" HorizontalAlignment="Left"></TextBox>
    Please refer the same from the attached sample. (see NumericFormat.zip)
    NumericFormat.zip
