Possible Memory Leak in C1PdfViewer
Posted by: tobias.heilmannseder on 7 September 2018, 9:45 am EST
    Posted 7 September 2018, 9:45 am EST
    When I make a really small Wpf Application with only one C1PdfViewer Control it is using huge amounts of memory when I scroll pages.
    See attached solution.
  • Posted 7 September 2018, 9:47 am EST
    <Window
        x:Class="PdfViewerMemoryLeak.MainWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:c1="http://schemas.componentone.com/winfx/2006/xaml"
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:local="clr-namespace:PdfViewerMemoryLeak"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        Title="MainWindow"
        Width="800"
        Height="450"
        mc:Ignorable="d">
        <Grid>
            <c1:C1PdfViewer
                x:Name="C1PdfViewer"
                Focusable="True"
                Loaded="PdfHelpViewer_OnLoaded"
                OpenButtonVisibility="Visible"
                ToolbarVisibility="Visible"
                Visibility="Visible" />
        </Grid>
    </Window>
    using System;
    using System.Collections.Generic;
    using System.Linq;
    using System.Text;
    using System.Threading.Tasks;
    using System.Windows;
    using System.Windows.Controls;
    using System.Windows.Data;
    using System.Windows.Documents;
    using System.Windows.Input;
    using System.Windows.Media;
    using System.Windows.Media.Imaging;
    using System.Windows.Navigation;
    using System.Windows.Shapes;
    using C1.WPF.PdfViewer;
    namespace PdfViewerMemoryLeak
        /// <summary>
        /// Interaction logic for MainWindow.xaml
        /// </summary>
        public partial class MainWindow : Window
            public MainWindow()
                InitializeComponent();
            private void PdfHelpViewer_OnLoaded(object sender, RoutedEventArgs e)
                if (sender is C1PdfViewer c1PdfViewer && c1PdfViewer.IsVisible)
                    c1PdfViewer.ViewMode = ViewMode.FitWidth;
                    c1PdfViewer.LoadDocument(@"..\..\made-with-cc.pdf");
  • Posted 10 September 2018, 12:45 am EST - Updated 4 October 2022, 9:14 am EST
    Thank you for sharing the code snippets. I am able to reproduce the issue at my end.
    Could you please try loading your PDF using the C1FlexView/C1PdfDocumentSource controls. For this, I would suggest to use the product sample installed at \Documents\ComponentOne Samples\WPF\C1.WPF.Document\CS\PdfView location and verify the behavior at your end.
    I would also suggest you to move your application to use C1PdfDocumentSource which should work fine. Please refer attached video.
    Ruchir
