Prevent DockTabControl Floating outside parent control
Posted by: vinothkumar.r2210 on 21 May 2020, 6:26 am EST
    Posted 21 May 2020, 6:26 am EST - Updated 4 October 2022, 8:54 am EST
    How to prevent docktabcontrol floating outside parent control. Please find the attached image.
    Also when floating completed and not docked then the docktabcontrol not returned to its original position.
    Thanks and Regards,
    Vinoth Kumar Ravi
  • Posted 22 May 2020, 4:10 pm EST
    Hi Vinoth,
    I would suggest you to try using C1DragDropManager and handle its DragLeave event. Below is sample code snippet for same.```
    C1DragDropManager dd = new C1DragDropManager();
    foreach (UIElement e in _docktab1.Items)
    dd.RegisterDragSource(e, DragDropEffect.Move, ModifierKeys.None);
    foreach (UIElement e in dockControl.Items)
    dd.RegisterDropTarget(e, true);
    dd.RegisterDragSource(_docktab1, DragDropEffect.Move, ModifierKeys.None);
    dd.DragLeave += Dd_DragLeave;
    private void Dd_DragLeave(object source, DragDropEventArgs e)
    var dragSource = e.DragSource as C1.WPF.Docking.C1DockTabControl;
    if(dragSource!=null)
    var parent = dragSource.Parent as C1.WPF.Docking.C1DockControl;
    if (parent!=null)
    if(parent.IsMouseCaptureWithin ==false && parent.IsMouseDirectlyOver == false )
    e.Effect = DragDropEffect.None;
    Ruchir
