Property grid order
Posted by: kisar on 13 November 2020, 6:10 am EST
    Posted 13 November 2020, 6:10 am EST
    is it possible order the property grid different than alphabetic?
    is it now possible hide password characters?
    Thanx
  • Posted 17 November 2020, 7:57 am EST
    Hi Kisar,
    1) Sort Order: C1PropertyGrid provides various Sorting behaviors by using PropertySort property. If you need to specify custom sort order, you can set PropertySort = Custom and use Display(.Order) attribute on property to specify the order explicitly:
    propGrid.PropertySort = C1.WPF.Extended.PropertySort.Custom;
    [Display(Order = 5)]
    public DateTime DOB { get; set; }
    For a set of supported Property Grid attributes, you can refer to ‘https://www.grapecity.com/componentone/docs/wpf/online-extended/SupportedPropertyGridAttributes.html?highlight=sort%2C’.
    2) Password Editor: Passwords are generally strings and for string types, C1PropertyGrid uses StringEditor (Textbox). So, we need to create a custom editor for passwords that will display PasswordBox as an editor. For details, you can refer to ‘https://www.grapecity.com/componentone/docs/wpf/online-extended/CreatingCustomEditors.html’.
    Please refer to the attached sample for the above implementations.
    Basant
    SortPropertyGrid.zip
