Posted 27 June 2018, 1:16 pm EST
Greetings,
When using C1Preview to create a custom PDF using RenderObjects. I am having issues adding an Image to a TableCell via TableCell.Image. It appeared that the image being rendered was only displaying 75% of the width and height of the actual image. When I switched to a different machine to create a test program to supply as an example I found that the issue didn’t appear. I was able to track down the issue to being the Windows Scaling on 4k monitors being set to 125% compared to other monitors with scaling set to 100%. Once I changed my 4k system to 100% scaling the image appeared just fine.
Is there a setting somewhere that I can’t seem to locate that will keep the images from being truncated if the end user has windows scaling something other that 100%?
Sample attached.
Norm
