Posted 20 November 2017, 3:07 am EST
You can set you MVVM property in MouseRightButtonDown event as below:
private void C1TreeView_MouseRightButtonDown(object sender, MouseButtonEventArgs e)
Point p = e.GetPosition(treeview);
var ControlType = treeview.InputHitTest(p);
if (!(ControlType is Border))
var node = treeview.GetNode(p);
node.IsSelected = true;
dataitems.MySelectedItem = node.DataContext as Item; // Set MVVM property here
Also, find a sample application attached.
Note: You can modify attached sample accordingly.
Singh
TreeViewRightMouseSelect.zip
