Posted 13 September 2019, 4:01 am EST
It seems that the columnfiltereditor sort the values as string instead of integers even if the column is binded to an integer.
Any way to resolve this ?
Forums Home / ComponentOne / WPF Edition
Posted by: mdy20 on 13 September 2019, 4:01 am EST
Posted 16 September 2019, 4:54 am EST
I am unable to reproduce the issue with the attached application. Please refer to the attached application. Could you please check with the latest version. You can download the same from the following link:
http://prerelease.componentone.com/dotnet40/c1wpflibrary/2019-t2/C1WPFBasicLibrary.4_4.0.20192.658.zip
If the problem still occurs them, Could you please either modify the attached application or provide your own stripped-down application so that I can try reproducing the same behavior at my end and assist you further accordingly?
