SpreadGrid Scroll Mouse Press Move
Posted by: quockhanhk15tpm on 17 June 2022, 4:22 am EST
    Posted 17 June 2022, 4:22 am EST
    Hello
    I using GcSpreadGrid.
    How using Scroll by press and move mouse.
    I have set the properties
    PanningMode=“VerticalOnly”
    BoundaryFeedbackMode=“Split”
    Please help me.
  • Posted 20 June 2022, 5:49 am EST
    Could you please provide some more information that What you want to achieve?
    Scroll by press and move mouse on Scroll-bar or cells?
    Scrolling By Pressing and moving mouse on scroll-bar already scrolls the SpreadGrid.
    If you are trying to scroll by pressing and moving mouse on cells, the selection behavior and editing will not work.
    If we understood wrong, then please correct us and clarify your requirement.
    Nitin.
  • Posted 21 June 2022, 3:46 am EST - Updated 4 October 2022, 8:29 am EST
    Yes. I trying to scroll by pressing and moving mouse on cells.
    Please help me.
  • Posted 21 June 2022, 11:25 am EST
    Thanks for the snapshot and clarification.
    In order to scroll by pressing and moving mouse on cell, you need to handle PreviewMouseDown, PreviewMouseMove and PreviewMouseUp event as:
           private void GcSpreadGrid1_PreviewMouseUp(object sender, MouseButtonEventArgs e)
                _isDragging = false;
            private void GcSpreadGrid1_MouseMove(object sender, MouseEventArgs e)
                if(_isDragging & e.LeftButton == MouseButtonState.Pressed)
                    var hitTest = gcSpreadGrid1.HitTest(e.GetPosition(gcSpreadGrid1)) as CellHitTestInfo;
                    if(hitTest !=null)
                        if (initialRow > hitTest.RowIndex & GetViewBottomRow() + 1 != gcSpreadGrid1.Rows.Count)
                            gcSpreadGrid1.ShowRow(GetViewTopRow() + 1, VerticalPosition.Top);
                        else if (initialRow < hitTest.RowIndex & GetViewTopRow() != 0)
                            gcSpreadGrid1.ShowRow(GetViewBottomRow() - 1, VerticalPosition.Bottom);
                    e.Handled = true;
           private void GcSpreadGrid1_PreviewMouseDown(object sender, MouseButtonEventArgs e)
                _isDragging = true;
                var ht = gcSpreadGrid1.HitTest(e.GetPosition(gcSpreadGrid1)) as CellHitTestInfo;
                if(ht != null)
                    initialRow = ht.RowIndex;
            private int GetViewTopRow()
                int topmostRow = 0;
                for (int row = 0; row < gcSpreadGrid1.Rows.Count; row++)
                    for (int col = 0; col < gcSpreadGrid1.Columns.Count; col++)
                        if (gcSpreadGrid1.IsCellInView(row, col))
                            topmostRow = row;
                            row = gcSpreadGrid1.Rows.Count;
                            break;
                return topmostRow;
            private int GetViewBottomRow()
                int bottomMostRow = 0;
                for (int row = gcSpreadGrid1.Rows.Count-1; row >= 0; row--)
                            bottomMostRow = row;
                            row = -1;
                            break;
                return bottomMostRow;
    Please refer the attached sample for the same : SpreadSample.zip
    Nitin.
  • Posted 21 June 2022, 10:27 pm EST
    Thanks for you answer.
    It’s work.
