Tab Order Reversed in C1DataGrid
Posted by: Swapnil.Walwadkar on 23 October 2018, 4:09 am EST
  • Posted 23 October 2018, 4:09 am EST
    I am using the C1DataGrid 4 to display some C1NumericBoxes, ComboBoxes, etc dynamically. My issue is that when running my code and I attempt to tab my way through the boxes, the tabbing works backwards as if I am pressing Shift+Tab. The Tab Order is getting reversed.
    Please let me know the solution for it.
  • Posted 24 October 2018, 4:59 am EST
    Hello Swapnil,
    Could you please try to run the attached application wherein I have implemented your scenario by handling the PreviewKeyDown Event of C1DataGrid.
    Also, please share the ComponentOne build version that you are using.
    RuchirTabNav_C1DataGrid.zip
