Treeview Shift-Click to select multiple items in sequence
Posted by: dphillips on 30 June 2022, 3:11 pm EST
    Posted 30 June 2022, 3:11 pm EST
    Is there a way to allow the user to click on the 1st item in the treeview, and then shift+click on a later item and have it select all items in between?
  • Posted 1 July 2022, 3:32 am EST
    You need to handle ItemExpanded event to select 1st item on expanding a Parent node as:
            private void Item_Expanded(object sender, SourcedEventArgs e)
                var node = e.Source as C1TreeViewItem;
                if(node != null)
                    if(node.HasItems)
                        node.FirstNode.IsSelected = true;
    In order to achieve the requirement to select items using Shift+Click. You need to set SelectionMode=True. On expanding parent node the first item will be selected and then shift+click on a later item will select all items between them.
    Please refer the attached sample for the same : C1TreeViewSample.zip
    Nitin
