Unable to generate PDF Preview
Posted by: mayur.purandare on 26 May 2021, 10:42 am EST
    Posted 26 May 2021, 10:42 am EST
    Facing issue in PDF Generation and PDF Preview while executing following code.
    C1PdfDocument c1PdfDocument = GetC1PDFDocument();
    C1PrintDocument c1PrintDocument = GetC1PrintDocument();
    RenderTable renderTable = GetRenderTable(); // some data is added (contains images)
    c1PrintDocument.Body.Children.Add(renderTable);
    c1PrintDocument.Generate();
    foreach (C1Page page in c1PrintDocument.Pages)
        c1PdfDocument.NewPage();
        img = page.AsMetafile(); //Exception
        c1PdfDocument.DrawImage(img, c1PdfDocument.PageRectangle);
    c1PdfDocument.Save(SavePath);
    Component used: C1.WPF.C1Report.4.dll [Version: 4.0.20203.457]
    Stacktrace is in the attachment.
  • Posted 26 May 2021, 10:49 am EST
    Adding the Stacktrace in the comments:
    ************************************************************** Exception Stack **************************************************************
    Parameter is not valid. at System.Drawing.Graphics.set_PixelOffsetMode(PixelOffsetMode value)
    at C1.C1Preview.GraphicsUtils.DrawImage(Graphics graphics, Image image, RectangleF drawRect, RectangleF clipRect, IImageAlign align, IMetafilePainter metafilePainter, Boolean useClassicDrawMethod)
    at #w3i.#VOj.Draw(Image #gjc, ImageAlign #wrc, Graphics #0p, Rectangle #Mi, Rectangle #TGj, Boolean #TOj, Boolean #qgc, Boolean #UOj)
    at C1.C1Preview.RenderGraphicsFragment.InternalDraw(Graphics graphics, DrawParams drawParams)
    at C1.C1Preview.RenderFragment.DrawContent(Graphics graphics, DrawParams dp)
    at C1.C1Preview.RenderFragment.#1Lj(Graphics #0p, DrawParams #Dr)
    at C1.C1Preview.RenderFragment.Draw(Graphics graphics, Rectangle boundsPx, Rectangle parentContentBoundsPx, Boolean renderChildren, PageDrawParams pdp)
    at C1.C1Preview.RenderTableFragment.#6Gj(Object #hEj, RenderFragment #qKf, Rectangle #7Gj, Rectangle #8Gj, Boolean #9Gj, Boolean #aHj, Boolean #bHj)
    at C1.C1Preview.RenderTableFragment.#eHj(#A4k #fHj, Object #hEj, #w4k #ZKf, Rectangle #gHj, Single #5lb, Single #6lb, Boolean #9Gj, Boolean #bHj)
    at C1.C1Preview.RenderTableFragment.#hHj(Single #5lb, Single #6lb, DrawParams #iHj, #x4k #jHj, #A4k #kHj, #z4k #lHj, #y4k #CGj, Object #mHj)
    at C1.C1Preview.RenderTableFragment.InternalDraw(Graphics graphics, DrawParams drawParams)
    at C1.C1Preview.C1Page.Draw(Graphics graphics, PageDrawParams pdp)
    at C1.C1Preview.C1Page.#jKj(Graphics #jbj, PageDrawParams #S8i)
    at C1.C1Preview.C1Page.AsMetafile(Graphics referenceGraphics, EmfType emfType, Boolean whiten, Boolean renderInputControls, SmoothingMode smoothingMode)
    at C1.C1Preview.C1Page.AsMetafile(EmfType emfType, Boolean whiten)
    at C1.C1Preview.C1Page.AsMetafile()
  • Posted 31 May 2021, 3:39 am EST
    I found, you are passing metafile as a parameter of DrawImage method. However, it takes as WriteableBitmap.
    Please check below link:
    http://helpcentral.componentone.com/nethelp/C1PDFWPF/C1.Silverlight.Pdf.5~C1.Silverlight.Pdf.C1PdfDocument~DrawImage(WriteableBitmap,Rect).html
    You can use below code for better understanding:
    private void Button_Click(object sender, RoutedEventArgs e)
                C1PdfDocument c1PdfDocument = new C1PdfDocument(PaperKind.A4);
                C1PrintDocument c1PrintDocument1 = GetPrintDocumentWithTable();
                c1PrintDocument1.Generate();
                foreach (C1Page page in c1PrintDocument1.Pages)
                    if (page.Index > 0)
                    Metafile img = page.AsMetafile(); //Exception
                    Stream stream = new MemoryStream();
                    img.Save(stream, ImageFormat.Bmp);
                    var bitmap = new BitmapImage();
                    bitmap.BeginInit();
                    bitmap.StreamSource = stream;
                    bitmap.EndInit();
                    bitmap.Freeze();
                    var wb = new WriteableBitmap(bitmap);
                    c1PdfDocument.DrawImage(wb, c1PdfDocument.PageRectangle);
                string filename = "test" + DateTime.Now.Ticks + ".pdf";
                c1PdfDocument.Save(filename);
                Process.Start(filename);
            C1PrintDocument GetPrintDocumentWithTable()
                C1PrintDocument c1PrintDocument1 = new C1PrintDocument();
                // Make a table.
                C1.C1Preview.RenderTable table = new C1.C1Preview.RenderTable(c1PrintDocument1);
                table.Style.GridLines.All = new C1.C1Preview.LineDef(Colors.DarkGray);
                // Add 3 rows.
                const int r = 3;
                // Add 3 columns.
                const int c = 3;
                for (int row = 0; row < r; ++row)
                    for (int col = 0; col < c; ++col)
                        if (!(row == 1 && col == 1) && !(row == 1 && col == 2))
                            C1.C1Preview.RenderText celltext = new C1.C1Preview.RenderText(c1PrintDocument1);
                            celltext.Text = string.Format("Cell ({0}, {1})", row, col);
                            // Add cells with text.
                            table.Cells[row, col].RenderObject = celltext;
                c1PrintDocument1.Body.Children.Add(table);
                return c1PrintDocument1;
    Hope, this will solve your issue. If this does not solve your issue then please share a small sample application with us, so that we can assist you accordingly.
