Posted 7 August 2018, 2:06 am EST
I am sorry for the inconvenience caused due to this. But I would like to assure you that it was not intentional and must have happened accidentally and we are checking how it got deleted.
Now regarding the issue, from our meta data the last response over that thread was the following:
Did you try running the sample I shared? It’s working at my end.
Also, as mentioned in the response earlier, for the approach to work you need to set Width to *. But your XAML code shows the Width set to Auto for few columns. Could you try to do that?
However, if still you are facing issues implementing the same in your application, could you please share your application or its stripped version !
Thanks & regards,
Ruchir
So, while we are finding the cause of the deletion of your original post, we request you to continue the discussion here.
Ruchir
