WPF flexgrid Unbound templated Checkbox column
Posted by: david on 16 March 2025, 8:15 am EST
    Posted 16 March 2025, 8:15 am EST
    How to set the checkbox for the Unbound Column?
  • Posted 17 March 2025, 5:02 am EST
    Hi David,
    You can create checkboxes for the boolean columns, by implementing a custom CellFactory for the unbound FlexGrid control. Here is the code snippet for the same:
    public class CheckBoxCellFactory : GridCellFactory
        FlexGrid grid;
        public CheckBoxCellFactory(FlexGrid fg)
            grid = fg;
        public override FrameworkElement CreateCellContent(GridCellType cellType, GridCellRange range, object cellContentType)
            if (cellType == GridCellType.Cell && grid.Columns[range.Column].ColumnName == "Select")
                CheckBox checkBox = new CheckBox
                    Margin = new Thickness(5),
                    HorizontalAlignment = HorizontalAlignment.Center
                // Set the checkbox state based on the grid's cell value
                object cellValue = grid[range.Row, range.Column];
                if (cellValue is bool isChecked)
                    checkBox.IsChecked = isChecked;
                // Handle CheckBox Click Event
                checkBox.Checked += (s, e) => grid[range.Row, range.Column] = true;
                checkBox.Unchecked += (s, e) => grid[range.Row, range.Column] = false;
                return checkBox;
            return base.CreateCellContent(cellType, range, cellContentType);
    Kindly refer to the attached sample for full implementation. See CheckBoxCellDemo.zip
    Thanks & regards,
    Aastha
  • Posted 18 March 2025, 3:51 am EST
    Hi Aastha
    Thanks for your reply.
    I need to check/uncheck the checkboxes in code behind, not at creation.
    Thanks & regards
    David
  • Posted 19 March 2025, 2:22 am EST
    Hi David,
    You can fetch the Content of GridControlCellView returned via FlexGrid’s GetCellView() method. Here is the code snippet for the same:
    // You can initialize these variables based on your requirement
        int row = 2;
        int col = 0;
        bool isChecked = true;
        // code to check/uncheck the cell's checkbox via code
        GridControlCellView cellView = flexGrid.GetCellView(new GridControlRange(row, col));
        if (cellView.Content is CheckBox chk)
            chk.IsChecked = isChecked;
    Kindly refer to the attached sample for full implementation. See CheckBoxCellDemo_Mod.zip
    Thanks & regards,
    Aastha
