WPF Flexviewer localization
Posted by: sebastian-jn.k on 6 September 2021, 3:38 am EST
    Posted 6 September 2021, 3:38 am EST
    Doesn’t have wpf flexviewer language support like pdfviewer?
    Xaml property language=“de-DE“ doesn‘t work.
    Greens
  • Posted 6 September 2021, 8:36 am EST
    Hello Sebestian,
    It seems like you are not setting culture with the Language property.
    You can set culture as :(see code snippet)
    Thread.CurrentThread.CurrentUICulture = new System.Globalization.CultureInfo("de-DE");
    Please refer the attached sample for the same : (see FlexViewerLanguage.zip)
    Nitin
  • Posted 7 September 2021, 4:28 am EST
    hello,
    i already tried that.
    I also tried to set the CurrentUICulture/CurrentCulture on Application_Startup event handler, nothing worked for me.
    By the way, my apllication/thread already starting with de-DE Culture.
    Pdfviewer worked for me out of the box with german language.
    If i run the sample i don’t see german language too, only default english.
    I used C1.WPF.Flexviewer.4.5.2 Version 4.5.20201.697 with .NET targetframework 4.8.
    greetings from germany
  • Posted 7 September 2021, 7:07 am EST
    Hi Sebestian,
    JFYI, German Language localization is added into 2020v2 till latest build and you are using 2020v1. You can refer https://www.grapecity.com/componentone/docs/wpf/online-releasehistory/2020v2.html
    In order to change language as “de-DE” in your FlexViewer application, we suggests you to upgraded to the latest build.
    Nitin
