WPF NumericBox allowing Hex or Bin Numbers
Posted by: mayur.purandare on 22 October 2018, 3:34 am EST
    Posted 22 October 2018, 3:34 am EST
    Is there any way such that the C1 NumericBox can be used to enter Hexadecimal or Binary Text only.
  • Posted 23 October 2018, 7:48 am EST
    Hello Mayur,
    As per my understanding it not possible to have both formats in a single C1NumericBox instance. So, I have implemented these in two seperate C1NumericBox using Format and handling the PreviewKeyDown event.
    Please refer attached sample application “” and let me know, if there are any issues.
    RuchirFormat_C1NumericBox.zip
  • Posted 23 October 2018, 11:43 pm EST
    Thanks a lot Ruchir.
    I will go through this and will get back.
    Mayur
  • Posted 24 October 2018, 3:27 am EST
    Hello Ruchir,
    Thank you for sharing the sample.
    I tried to run it.
    It worked well for Hexadecimal.
    However, for binary, the up-down buttons were not working. Decimal digits were also getting added.
    There is only event “ValueChanged” which gets triggered by changing the value using up-down buttons on the control. However it does not allow to intercept.
  • Posted 26 October 2018, 2:38 am EST
    Hello Ruchir,
    Thank you so much for sharing the sample.
  • Posted 26 October 2018, 6:14 am EST
    Hello Mayur,
    I have forwarded your request [ID: 350215] to support Binary format in C1NumericBox.
    Meanwhile, I modified and attached the sample for Binary values. Could you please test the same at your end and share your observations.
    Ruchir
  • Posted 1 November 2018, 2:12 am EST
    Hello Mayur,
    Developer has made few modifications in the sample we shared earlier for supporting Binary format in C1NumericBox. Therefore, we request you to kindly refer to the attached sample.
    Let me know, if you find some issues using it.
    Ruchir
    Format_C1NumericBoxEnhanced.zip
